Steering Column lock dis-mantle & interchangability –HEP ME
Postby crossy » Sun Apr 13, 2014 6:17 pm
The 89 CTD automatic truck I just bought is in need of a steering column. BUT FOR RIGHT NOW I JUST WANT TO GET IT UNLOCKED SO I CAN STEER IT.
I never stole cars so I am not familiar with WHAT LOCKS the steering on this year Dodge, usually a pin and or rod , but I need to know how to discombobulate(like that techy term?) the lock so I can steer it. I am not worried about starting it as of yet. So I don’t bust everything in it. I plan on a junkyard hunt later on for a list of many parts I need including the column . I know in 88 they went to stalk controls, but I think they changed to columns again in 91?. so am I limited to 88-90 on this WHOLE column replacement the way I see it? Thanx , Crossy.
1990 D250, 5spd, 3.54, 35K miles,' Lomi '
1991 D250, 5spd, 3.54LS, fix-r-up toy, all stock,resto,'Pbob'
1992 D250, 5spd, 3.54LS,'CandyCane', almost daily driver
1992 W250,CC,auto,3.54LS,Picker
1990 D250,auto, 3.07, 'Doubleblue'
1973 Pinto w/ 13"cragars- ewww!
Sold 9 other 1st Gens that WE saved from death :-) and 3 that I couldn't save:-( - not counting gassers
crossy
Re: Steering Column lock dis-mantle & interchangability –HEP ME
Postby dazedandconfused » Sun Apr 13, 2014 6:26 pm
If the column is good and upu just need a key call a locksmith. Its the cheapest and easiest thing to do. I've done this a handful of times.
Postby crossy » Sun Apr 13, 2014 6:50 pm
The Column is NOT in good shape ,hence the replacement idea. PO dicked up the whole left side of it besides loosing the dang key. just want to unlock it for now. thanx , crossy
crossy
Postby DodgeFreak » Mon Apr 14, 2014 5:10 am
I've drilled out the tumbler before...just be careful you don't break a bit in it.
Postby crossy » Mon Apr 14, 2014 11:41 am
DodgeFreak wrote:I've drilled out the tumbler before...just be careful you don't break a bit in it.
ahhhhhhhluck you say, lol , well as long as iam relying on luck I might aswell try the 6 dodge truckkeys I have here to see if any of those work. thanx. crossy
crossy
Postby DodgeFreak » Mon Apr 14, 2014 11:42 am
you might get lucky...I know my colum on my 92 4wd will take any key..you just need to wiggle it alittle to get it to turn lol.
Postby PToombs » Mon Apr 14, 2014 4:51 pm
Pull the steering wheel and remove a few parts. When you get to the flat plate with all the slots on the edge, push that down, remove the snap ring on the shaft and pull the plate. Put the steering wheel back and and WA LA! unlocked!
Postby RumbleFish » Mon Apr 14, 2014 6:42 pm
Sounds like Pete has done this a few times before!
Postby crossy » Mon Apr 14, 2014 6:46 pm
sure toombs, now you tell me. lol I drilled it. had to go all the way up to a 3/8 bit before everything released. I can get it to crank now by grabbing the top rod (left side of column)and pushing it forward. thanx, crossy
crossy
Postby PToombs » Tue Apr 15, 2014 5:02 pm
Well, if you were an internet troll like most of us you would have been on sooner and seen it! :lol:
Jeff, wellllll, maybe. :mrgreen:
