Front end wobble 92 D350
Postby JimmyDUSMC35 » Mon Apr 14, 2014 7:17 pm
I've read several threads on this but mine is a little different. My front end doesn't start to wobble until over 70 mph or if I put the throttle to the floor and let off then it shakes like hell. The passenger front tire was worn really weird, so I replaced the tire yesterday and it still shakes like a SOB. Any ideas on what to look for and where to start ?
JimmyDUSMC35
Re: Front end wobble 92 D350
Postby RumbleFish » Mon Apr 14, 2014 7:47 pm
Worn tire? Id look into tie rods, ball joints, control arm bushings, wheels bearings etc. Any excess movement you find will contribute to this wobble youre feeling.
Postby diesel freak01 » Mon Apr 14, 2014 7:49 pm
I would start with checking wheel bearings and ball joints. Check the steering box to make sure it is attached and not loose. Check tie rods. I would bet its ball joints.
1993 d350 ctd drw 2wd auto
diesel freak01
Postby JimmyDUSMC35 » Mon Apr 14, 2014 8:04 pm
gonna start checing this tomorrow after work, thanks for the advice guys, hopefully its just a ball joint and/or wheel bearing
JimmyDUSMC35
Postby PToombs » Tue Apr 15, 2014 4:59 pm
Don't forget the strut bushings that hold the A arm in place.
Postby JimmyDUSMC35 » Wed Apr 16, 2014 5:46 pm
thanks guys, gonna check it out real good this weekend and hopefully cure the problem
JimmyDUSMC35
