Piping 4 in exhaust
Piping 4 in exhaust
Postby 92cummins89 » Sun Jun 29, 2014 1:58 pm
Finally have everything in trans, tease, front and rear drive shafts now time for the exhaust. I went with4 inch diamond eye have a quick question.... There is a cross member piece tht holds the trans and tcase up and two braces one on driver side one on passenger side my exhaust will not fit In between there do u just remove this brace and b done or is there another way thanks
92cummins89
Re: Piping 4 in exhaust
Postby CumminsPower59 » Sun Jun 29, 2014 2:12 pm
It'll fit...it's just real tight. On my 91, there is about 1/4" all around. You may have to flip how you are putting that piece in, takes a little English to get it through there and not hit anything when the clamps are all tightened. BTW, I hope you aren't using those gawd awful u bolt clamps, flat band clamps are the way to go. You won't have a huge fight if you have to remove the exhaust for some reason.
Postby Tacoclaw » Sun Jun 29, 2014 7:55 pm
I know I didn't bother, I took it out of there. You can't get the top three bolts out of the frame as they'll hit the body, but they don't hurt anything.
Postby 92cummins89 » Sun Jun 29, 2014 8:06 pm
I managed to get it in there with the cross member there just a little tight
92cummins89
Postby 92cummins89 » Sun Jun 29, 2014 8:13 pm
92cummins89
