Hub Nut Change
Hub Nut Change
Postby Diesel » Mon Jul 07, 2014 2:26 pm
On my rear 70 I have the nyloc style lock nut that uses those red tangs for locking. Is it possible to swap that to the 2 nut system? I replace those nyloc nuts every time I have it apart and would much rather just have the 2 reusable nuts. Part numbers would be great. Its a 1991.5 intercooled automatic single rear wheel.
1991.5 D250 Intercooled A518
Diesel
Re: Hub Nut Change
Postby BILTIT » Mon Jul 07, 2014 3:11 pm
Yes you can use the two nut system that is stock on the front dana 60's (w250/350's). I did it to mine so i know they work.
I got mine here:
http://www.partsmike.com/index.php?crn= ... how_detail
I do not know the original manufacturer part number though.
Derek B.
BILTIT
Re: Hub Nut Change
Postby Diesel » Mon Jul 07, 2014 5:23 pm
So you snug the one with the nub on it, install the one with the holes, then really torque the outer one with 4 slots? Thats it no other stuff to install?
Diesel
Re: Hub Nut Change
Postby BILTIT » Mon Jul 07, 2014 5:50 pm
Exactly.
Derek B.
BILTIT
Re: Hub Nut Change
Postby Diesel » Mon Jul 07, 2014 6:44 pm
Cool thanks. And this will fit the rear 70, right? I don't have a front 60.
Diesel
Re: Hub Nut Change
Postby CumminsPower59 » Mon Jul 07, 2014 7:26 pm
Correct. It isn't just a "snug" and go sorta deal, you can burn up bearings that way. I set mine exactly how the fronts are set, torqued to spec and backed off a certain amount. I don't have access to my FSM, otherwise I'd paste up a picture with the specs on it.
Re: Hub Nut Change
Postby BILTIT » Mon Jul 07, 2014 7:29 pm
I set my inner nut by feel, certain amount of drag (very little). I then tighten the outer as much as i can, you cannot get it too tight with the prong style socket as it will slip after so much.
And yes for the rear 70.
Derek B.
BILTIT
