Which ball joints?
Which ball joints?
Postby jdiesel_us » Wed Jul 16, 2014 6:59 am
Ok I have a 91 non intercooled w350. When I look at rockauto.com it offers 2 different ball joints how do I determine which ones I need?
jdiesel_us
Re: Which ball joints?
Postby DodgeFreak » Wed Jul 16, 2014 8:50 am
if you have a w350 you don't have ball joints you have king pins.
Postby oldestof11 » Wed Jul 16, 2014 1:59 pm
You have a 4500lbs front axle.
Postby jdiesel_us » Wed Jul 16, 2014 2:59 pm
ok I must be mistaken it is a 2wd dually, so I know it has ball joints, is it a d350 then?
jdiesel_us
Postby ellis93 » Wed Jul 16, 2014 4:27 pm
Yep,D is 2 wheel peel.
Buy nothing but Moog parts and you should have the 4k axle
Re: Which ball joinjts?
Postby v8coupe » Thu Jul 17, 2014 5:33 pm
I just did this on my non-ic 91 D350. I ended up needed both upper control arms because they were both cracked out at the ball joint area. One failed which is what caused me to do the whole front suspension.
v8coupe
Postby jdiesel_us » Fri Jul 18, 2014 12:45 pm
Wow I just checked mine for play but I hope I don't need several other parts like control arms.
jdiesel_us
