Leaf springs
Leaf springs
Postby Darkride » Sat Aug 30, 2014 4:33 pm
Can i put a w350 leafs springs in the rear end of my w250 to beef it up?
Darkride
Re: Leaf springs
Postby CumminsPower59 » Sat Aug 30, 2014 4:41 pm
You could. Just be careful not to overload it, as just because it has heavier springs doesn't mean it can carry more weight, it can carry it better though, i.e., less sag with a load. It will stiffen things up a bit too. My W350 had so many stress cracks from years of bouncing around from the overly stiff springs, the be had only two areas that were attached to the frame. All the others had cracked apart. Adding helper/overload springs and/or air bags is an alternative, and can net better empty ride results.
Re: Leaf springs
Postby Darkride » Sat Aug 30, 2014 7:08 pm
Okay so does anyone know which aftermarket springs are the best to lift the front end a few inches?
Darkride
Re: Leaf springs
Postby BILTIT » Sat Aug 30, 2014 7:28 pm
Alcan, Deaver, Atlas
You can do 1" with these:
http://diy4x.com/cart/index.php?route=p ... uct_id=128
Derek B.
BILTIT
Re: Leaf springs
Postby Darkride » Sat Aug 30, 2014 8:38 pm
will i be able to clear 285/75r16 with those installed?
Darkride
Re: Leaf springs
Postby BILTIT » Sun Aug 31, 2014 9:28 am
Depends on the state of your existing leafs. Pretty sure that is the size of tire i run with new 2" lift springs.
Derek B.
BILTIT
Re: Leaf springs
Postby CumminsPower59 » Sun Aug 31, 2014 11:16 am
I ran 285's on the stock steel wheels for a while on my 92 with sagged front springs, and no rubbing of the fenders...I did have to trim the very bottom leading edge of the fender trim. I ran 305/70 17's on 3rd gen wheels, and they would rub the drag link a little at full right, no biggie for me, but everyone has their own preferences ;)
Re: Leaf springs
Postby Darkride » Sun Aug 31, 2014 12:18 pm
Where did you get you're 2 inch leafs at?
Darkride
Re: Leaf springs
Postby BILTIT » Sun Aug 31, 2014 2:07 pm
Alcan
Derek B.
BILTIT
Re: Leaf springs
Postby RCCUMMINS89 » Thu Sep 04, 2014 5:00 pm
I run and recommend Atlas leaf springs... had nothing but rave reviews on them, they offer an expedition pack. The expedition pack is a "towing" pack. Rides better than stock, but stiffens up quick and is strong for a heavy load.
