How big of a tire before needing a lift?
Postby Bschwarzli » Wed Oct 01, 2014 2:55 pm
Hey Guys,
I am wanting to stick a 245/70/19.5 under the crew cab. That works out to a 33.0/9.65/19.5 in english.
But I am worried about hitting the fender when I turn or the leaf spring.
So question is, anyone know what max tire sizes that one can stick under a truck at stock ride height? I am sure someone must have tried larger tires!
Thanks!
Robert
1993 W350 Dually Crew Cab - 1997 12V, NV5600, NP205, Dana 60 F, Dana 80 R, Gear Vendors, PDR Twins, 4 link rear, so mostly stock really :)
1990 W250, NV5600, 3.07s, Gear Vendors, Super HX40, kinda stock :D
Bschwarzli
Re: How big of a tire before needing a lift?
Postby Horicon93 » Thu Oct 02, 2014 6:03 am
I have spun 225/70/19.5's on my 2WD, so I would think the 245's would clear on a 4WD. Just my .02 worth :)
'93 Extended Cab, DRW, 2WD, Auto, 4 1/2" stacks, Bone Stock
Horicon93
Postby DodgeFreak » Thu Oct 02, 2014 2:40 pm
I'm running 33x12.50x16.5s according to this there yours are pretty much the same size.
Postby DodgeFreak » Thu Oct 02, 2014 2:44 pm
I will say this also they will rub the fender if I off road it BUT my cab and stuff is all rusted out, so the body flexes really badly.
Postby Bschwarzli » Thu Oct 02, 2014 2:48 pm
That helps guys! Thanks! If your 33's are fitting, at that much wider, I should be fine. And if 225 will fit a 2wd, I agree with your theory as well.
Thanks guys!!
Bschwarzli
Postby RumbleFish » Thu Oct 02, 2014 3:22 pm
Im running 255/85-16 which is roughly 33.5x10 and it cleared everything even before I lifted the front 2.5"
Postby Tacoclaw » Thu Oct 02, 2014 3:30 pm
Only thing to watch out for is since they're 19.5's they may tuck in a good bit. It'll help them clear the fenders, but may cause some interference with your draglink. Depends on how skinny they are.
Here's the setup I always use, it's super-handy if you know your offset and stuff.
https://rimsntires.com/specspro.jsp
Postby Bschwarzli » Mon Oct 06, 2014 5:56 am
Thats a good link Taco! Thanks!
Rumble: Thanks. That helped. Wheels now ordered.
Bschwarzli
