92 dana 70 and 70's dana 70.
Postby DodgeFreak » Tue Oct 07, 2014 2:34 pm
Would it be possible to swap 3.55 gears and posi out of a 92 into a 74ish dana 70 dually rear end?? I assume the rear is a 70s rearend is a dana70.
Re: 92 dana 70 and 70's dana 70.
Postby Tacoclaw » Tue Oct 07, 2014 4:23 pm
You know the BOMs of either one?
Postby DodgeFreak » Wed Oct 08, 2014 6:39 am
Nope they are 4 hours south of me at the moment. Is that stamped on the axle??
Postby Tacoclaw » Wed Oct 08, 2014 8:24 am
Yeah, supposedly on the forward, passenger side of the pumpkin, though I couldn't find it on either of mine. =\
Here's the "bible" on them, Not as much info as the 60 bible but it may help.
http://www.pirate4x4.com/forum/chevy/52 ... hread.html
Postby wheelerfreak » Sun Oct 19, 2014 2:56 pm
The 74 Dana 70 should be a 35 spline axle. Your 92 dana 70 will be a 32 spline if it's from a w/d250, and a 35 spline if it's a dually 70. The gears should work but the posi won't unless they are both the same axle spline count or you swap the axle shafts too, if they are the same width.
wheelerfreak
