Wheel stud p/n?
Wheel stud p/n?
Postby bmoeller » Sun Nov 30, 2014 9:05 am
I know its been brought up before, but haven't found it doing a search. :?
Need a part number for the studs, so I replace all the wheel studs on my 93 and also on the front of the crew cab. Wanting to convert them all over to 9/16" studs, like the 2nd gens are.
Crew cab has a Dana 80 under and want the fronts to match. Plus, with the mag style nuts on the alum dually rims, the 9/16 stud will allow for a thinker shank on the nuts. Less change of damage. Already had one idiot damage a few of the 5/8" nuts and threads, using a friggin impact wrench putting them on! Specifically asked to have the guy use a torque wrench. NOPE! :evil:
TIA!
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Re: Wheel stud p/n?
Postby CumminsPower59 » Mon Dec 01, 2014 8:15 pm
Easy way? Find a set of GM D60 DRW hubs.
Here's the problem, the front studs (5/8") on your 93 have a knurl diameter of 0.715"/0.724", the 9/16" studs have a knurl diameter of 0.650. Won't fit. The GM DRW hubs have smaller stud holes, of the proper 0.650" diameter.
GM DRW front studs...
http://www.dormanproducts.com/mobile/p- ... origin=YMM
Your front studs...
Extra long 9/16" studs...(knurl diameter is the same 0.65-ish)
Hope this helps!
