D70 master rebuild kit
Postby Farmboy » Wed Dec 17, 2014 10:10 am
I am going to be swapping from D70 SRW to D70 DRW. the DRW axle is empty except the axle shafts to the drums.. that is all complete. I am going to take the carrier assembly, ring and pinion from my SRW axle. So while I have it apart I am going to replace all the bearings and seals.
anybody have a part number for the rebuild kit?
Was looking at Rockauto.com and they have a ton of different kits, I just want to make sure I get the right one.
Need one with all the bearings, seals, crush sleeve, pinion nut, shims, etc...
While I would like Timken bearings. A reliable cheaper bearing would be preferred.. Trying to keep cost down as much as possible. yeah I am as cheap as everyone else one here.. :roll:
Farmboy
Re: D70 master rebuild kit
Postby Farmboy » Wed Dec 17, 2014 10:17 am
I am looking at this kit right now...
DORMAN Part # 697108
Farmboy
Postby Farmboy » Fri Dec 19, 2014 8:37 am
how about this.. anybody at least know if the D70 has a 9.25 ring gear? If not, this kit is not the right one.
Farmboy
Postby Tacoclaw » Fri Dec 19, 2014 9:40 am
Here, dig around in this. There's a couple links in it that will take you to Spicer's page, you can get their #'s and go from there.
viewtopic.php?f=3&t=16088&hilit=+BOM
Postby Farmboy » Fri Dec 19, 2014 10:24 am
hey.. thats exactly what I was looking for!!
Farmboy
Postby Tacoclaw » Fri Dec 19, 2014 4:38 pm
Glad I could help, I realy need to start digging around for some info to add to that thread.
You gonna give me those 35spl SRW axleshaftsfor the help? :mrgreen:
Postby Farmboy » Mon Dec 22, 2014 5:54 am
if you are in need I am sure we can work something out. Will probably be selling the whole axle or parting it out or something along those lines.. Nice thing is your are close..
Farmboy
