Rear brake drum/shoe sizes
Postby rollieD250 » Tue Jan 06, 2015 9:20 am
I am trying to replace the drums/shoes on my 92 D250 project truck, anyone know what ones i need? I keep seeing 11" or 12" wide
I need 2.5" wide i believe?
Even on rockauto i am really confused, advance/autozone/napa/rockauto part #'s would be sweet
Thanks alot guys!
1992 D250
THD fuel pin, 3200 spring, 57/65/14, timing spacer, 3pc manifold, piston lift pump, ASA intake
rollieD250
Re: Rear brake drum/shoe sizes
Postby matthewh » Tue Jan 06, 2015 10:39 am
If you have the stock Dana 70 rear axle, there 12x2.5 shoes. You can upgrade and run 12x3" shoes for better braking power, just look up a D350, as they run wider shoes
matthewh
Postby CumminsPower59 » Tue Jan 06, 2015 11:20 am
12" D/W250 drums, 3" wide (12"x3") D/W350 shoes.
Postby ellis93 » Tue Jan 06, 2015 12:04 pm
matthewh wrote:If you have the stock Dana 70 rear axle, there 12x2.5 shoes. You can upgrade and run 12x3" shoes for better braking power, just look up a D350, as they run wider shoes
If you had 2 1/2 shoes and you want to run threes like above,you have to cut the drums surfaces As well
Postby CumminsPower59 » Tue Jan 06, 2015 12:18 pm
Aren't the 12" drums the same or are the 2.5" only cut 2.5"? I figured all the 12" drums would already have 3" wide surfaces already...?
Postby ellis93 » Tue Jan 06, 2015 12:29 pm
CumminsPower59 wrote:Aren't the 12" drums the same or are the 2.5" only cut 2.5"? I figured all the 12" drums would already have 3" wide surfaces already...?
Same drums,wear surface will be worn in at whatever width the old shoe was tho. I'd not put wider shoes in a small shoes rut.
Postby matthewh » Tue Jan 06, 2015 3:14 pm
I had the impression he was replacing the drums as well, otherwise yes id have them resurfaced as well
matthewh
Postby ellis93 » Tue Jan 06, 2015 4:37 pm
matthewh wrote:I had the impression he was replacing the drums as well, otherwise yes id have them resurfaced as well
Good god....I need to quit scanning over treads :lol:
Postby rollieD250 » Tue Jan 06, 2015 5:32 pm
Thank you for all the help guys i really appreciate it cant wait to get thing thing on the road
1992 D250
rollieD250
Postby cougar » Sun Jan 11, 2015 9:29 am
You should also upgrade your slave cylinders to the 1 ton as well. They are a 1.125" bore vs a 1" bore. GM used a 1.187" on the same axle, another option.
01 2500 "the work truck".
cougar
