Limited slip diff
Limited slip diff
Postby Jelmer » Tue Jan 20, 2015 12:51 am
My 93 2wd has a open rear end but I would like to have a limited slip in it. In my BMW I have a clutch style lsd which you don't feel when turning so I would like to have something like this in my Dodge.
Any suggestions?
Greetings from the Netherlands where there are only 2 or 3 1stgens!
93 D250 Cummins, G360, 4" stainless exhaust, BHAF, DennyT stage 2 pin, 3200rpm governor spring, 12cm housing, rest stock.
03 VW Bora 1.6
83 Datsun Laurel 4.5 32v V8
84 Nissan Patrol 2.8i
Jelmer
Re: Limited slip diff
Postby CumminsPower59 » Wed Jan 21, 2015 11:21 am
The Spicer Power-Lok is a great limited slip. Was a factory option for our trucks, easily rebuilt, and plenty of parts still available.
Postby qmikep » Wed Jan 21, 2015 7:00 pm
You may want to look into a detriot trutrac. You get a limited slip that doesn't have clutch discs that wear out.
qmikep
Postby CumminsPower59 » Wed Jan 21, 2015 8:26 pm
All steel clutches will fix that ;)
Postby Landmissile » Sun Jan 25, 2015 11:12 pm
qmikep wrote:You may want to look into a detriot trutrac. You get a limited slip that doesn't have clutch discs that wear out.
x2 on the Detroit Trutrac. No clutches to rebuild and it still uses standard gear oil. Clutch type LSD's generally use a light oil like tranny fluid, or actual tranny fluid. I always run the Trutrac in the rear of my street driven rigs. Never had an issue.
1990 Cummins W250 Foolsize
Landmissile
Postby CumminsPower59 » Mon Jan 26, 2015 4:53 am
Never seen any LSD use anything but gear oil. Generally, a friction modifier is added to the gear oil for the clutches...
Postby coodah » Mon Jan 26, 2015 9:28 pm
I went with a Powr-Lok and have been very happy with it. As already mentioned, easy to come by and parts are readily available. It does not make any difference which design you go with, when you have moving parts sliding against each other, something has to wear. I would prefer to replace clutch packs, others may feel different.
90 W350 Cab-Chassis Truck, 5 spd, 93 W250 CC 5spd
coodah
Postby RCCUMMINS89 » Mon Jan 26, 2015 10:07 pm
True-trac doesn't make one for the Dana 70.....
Postby Jelmer » Tue Jan 27, 2015 2:08 am
I think we will go for the clutch type because we are familiar with these in our BMW's.
03 VW Bora 1.6
Jelmer
