Steering Column Shift Indicator Arm
Postby Craig229 » Tue Feb 24, 2015 10:26 pm
I own a 1992 Cummins 4X4 W250 with an automatic transmission. My problem is the shift indicator in the cluster doesn't work. I removed the cluster and found the PRND21 is in tact. I found the bracket/arm the indicator cable attaches to, that is riveted to the column, has been broken off.
My questions are, whats the name of that arm? Can I buy just the arm, and where? Any ideas on making one? Anyone have a good picture of one?
Side note, I called a local dealer in Vancouver WA and was given part #52077714 for the repair kit that is no longer available.
Thanks in advance for the help.
Craig229
Re: Steering Column Shift Indicator Arm
Postby PToombs » Wed Feb 25, 2015 5:54 pm
Have a local junkyard? Go take one off a truck there. Any truck from the 80's up to '93 should be the same, probably vans too.
Postby Craig229 » Wed Feb 25, 2015 9:35 pm
Thanks for the idea. Good to know the columns are all the same for those years.
I spoke to another dealer and the gal was nice enough to email me some photos of the bracket/arm. I made one out of some flat stock and it works great.
Off to the next repair...
Craig229
