A-Pillar Handles
A-Pillar Handles
Postby dr_funk » Sat Apr 25, 2015 8:08 pm
Has anybody installed handles on the a-pillars? Are there any aftermarket products out there for this, or is this a pure DIY mod?
dr_funk
Re: A-Pillar Handles
Postby simplysmn » Tue Apr 28, 2015 8:58 pm
It's a DIY thing I have never seen a grab handle on a first gen. but I'm sure with a blind nut you could make it work pretty well.
simplysmn
Postby thrashingcows » Sat May 02, 2015 3:12 pm
There was a member over on the DTR that did one a year or so ago...had a write up and pics. Looked pretty sweet!
thrashingcows
Postby matthewh » Sat May 02, 2015 4:52 pm
My dually came with one on the pass side, not sure what it came out of, but it uses the stock screw locations, just had longer screws installed to hold it
matthewh
Postby dr_funk » Sat May 02, 2015 8:17 pm
thrashingcows, do you have a link?
dr_funk
Postby thrashingcows » Sun May 03, 2015 8:59 pm
dr_funk wrote:thrashingcows, do you have a link?
Did a little digging...here ya go....post # 123 in member "User name's" thread about his truck.
http://www.dieseltruckresource.com/foru ... 263/page9/
thrashingcows
Postby dr_funk » Mon May 04, 2015 6:20 pm
Sweet, thanks!
dr_funk
Postby 1992gen1_fan » Thu May 14, 2015 4:35 am
I put some grab handles in my truck a long time ago. The came out of a '84 Subaru wagon lol but the screw holes lined up with the screws in the pillars and over door trim if I remember correctly.
1992gen1_fan
Postby 1992gen1_fan » Sat May 16, 2015 7:11 am
Here are the ones i installed in my truck Image
1992gen1_fan
Postby thrashingcows » Sat May 16, 2015 9:29 am
That's for the info, and the pics!!
thrashingcows
