Dodge dana 60 vs ford dana 60 (king pin)
Postby Paul » Fri Aug 28, 2015 6:04 pm
Does anyone know why the ford king pin 60 is better than the dodges?
Read that the ford axle is an upgrade but couldnt find out why.
Paul
Re: Dodge dana 60 vs ford dana 60 (king pin)
Postby matthewh » Fri Aug 28, 2015 8:44 pm
Only reason I've seen is due to ford being a driver side drop, versus pass side with the dodge. Clears alot of room for larger downpipe and you don't have to battle with front driveshaft, tcase, etc.
matthewh
Postby Paul » Fri Aug 28, 2015 9:00 pm
I didnt think of that
Guess i just assumed it was some strength or durability issue
Paul
Postby lz69 » Fri Aug 28, 2015 10:45 pm
Ford dana 60 fronts are driver side drop. The reason people like them is that they have a high pinion center which improves drive shaft ground clearance and lowers the front angle. They also use a reverse cut gear set which is a bit stronger then the low pinion axles.
lz69
Postby Paul » Fri Aug 28, 2015 11:08 pm
New to dodges, i knew the fords were hi pinion reverse cut. I figured the dodge was the same because it was the same era, after looking around seems like they were kinda exclusive to ford.
Paul
Postby Paul » Fri Aug 28, 2015 11:10 pm
Visually it just kinda looks like the low pinion ford 60s in the high boy fords is lower than the dodges
Paul
Postby oldestof11 » Sat Aug 29, 2015 10:35 am
I am pretty sure that Ford's also had dual piston calipers vs the Dodge single piston.
