Parking Brake not effective
Postby 93DodgeCummins » Tue Sep 29, 2015 8:55 am
Since I have owned my truck, the parking brake was never really effective. It will not hold it in place on the slight incline of my driveway. Are the parking brakes in these trucks just that bad or is there something else. I have replaced the drums, and pads not too long ago. I adjusted the pads so they were rubbing just a little. I thought I would have gotten better results on the parking brake. The cables are adjusted as well so the pedal returns when the brake is released.
93 Dodge W250 4X4, Custom air intake, Diamond Eye 4 inch turbo back straight pipe exhaust, HX-35W with Banks upgrades, KDP fixed, Getrag 5 speed, Isspro Tach, pyro, fuel pressure, and boost. Raptor 150, 3200 rpm spring, Power Screw in 1 turn, aftermarket fuel pin
93DodgeCummins
Re: Parking Brake not effective
Postby 1992gen1_fan » Tue Sep 29, 2015 5:43 pm
The parking brake in my truck actually held real well, I had replaced almost all the pieces in the drum and both rear cables and it worked real good when adjusted correctly
1992gen1_fan
Postby 93DodgeCummins » Sun Nov 15, 2015 4:40 pm
i got it figured out. just had to adjust the cable some more and made sure each drum was adjusted correctly. Thanks
93DodgeCummins
