differential overhaul question.......
Postby jethro » Sat Nov 14, 2015 11:05 pm
Hi all ..... been out a while .......
rear diff appairently had gotten water in the oil by previous owner.....
Pinion input had about 1/2 inch of slack (WOW)
May be the previous owner had a look-see as the nut was loose about 10 turns- but the front bearing (and race) was not
wildly trashed- maybe useable. However the ring and pinion were pretty pitted. So I decided it was overhaul time.
Put in a new Yukon 373 r+p and a Detroit truetrac diff. I think I have the variables mostly figured out-
(ford sterling 10.5) the preload on the pinion about 28 in-lbs- and about 7-8 thousanths backlash.
Paint pattern is basically centered in both directions on both sides.....
Here is the question- I made a fixed length sleeve to take the place of the crush sleeve. Don't want to deal with a
500 ft-lb torque to crush the thing. (if I can help it) Made a non-crushable sleeve out of seamless chrome-molly like
race car frame (about 1/8 wall). gradually cut it down in the lathe till it gives the correct pinion pre-load when using the
OLD front pinion bearing (which slides on and off the shaft - no interference fit)
At some point - (or now) I have to install the NEW front pinion bearing. It has a lot of interference to get pushed on.
So much so I am worried that once it is pushed on- I wont be able to remove it again. My concern is if the old and new bearings have a slightly different stack height- my carefully cut non-crushable bushing might be too tight or too loose-
and I wont be able to make adjustments because I wont be able to remove the front bearing.
I don't really see a good solution here ! Seems like too big a chance to take. This crap HAS to be right. Do I need
to abandon the non-crushing spacer and use the crushable one and bite the bullet and do a 500 ft-lb torqueing ?????
(and hope I don't overshoot.....)
(sorry - I never seem to have easy problems :D )
I have a new NAPA 3/4 inch drive long length flex handle - may have to get a 3/4 socket- not sure a 1/2 inch socket will do it-
Any thoughts will be appreciated !
Tim
PS - also working on lowering the suspension back down from a 9 inch lift - great fun.......
jethro
Re: differential overhaul question.......
Postby Remps » Sun Nov 15, 2015 12:48 pm
Use a 5 foot handle, and use a weigh scale with 100 lbs force to push on the end of it. 500 ft lbs. Maybe a flat pad on end of the handle to push on the scale. Hillbilly torque wrench lol.
Postby jethro » Sun Nov 15, 2015 11:54 pm
Thanks Remps-
I can probably use the hillbilly bar- but my bigger concern is the fit of the front bearing and the spacer......
tim
jethro
Postby Remps » Mon Nov 16, 2015 4:39 am
Sorry, the hillbilly bar was all I had to contribute. :lol: Are you speaking of the pinion yoke nut? Don't those have to be tightened to spec regardless?
Postby Primaris » Sun Dec 20, 2015 11:23 am
So does silence = fail? :/
Primaris
