power steering pump help...
Postby boostedve » Sun Dec 30, 2007 4:30 pm
i have a 1991 non i/c and the power steering is not workin like it should..
it only works after its warm and then it still doesnt work like it should. once i get to were im going and shut the truck off it pushs the fluid out the cap.. i have put synthetic fluid in it and also used lucas power steering fluid in it. no help..
brian i know we talked about this and i went to the junk yard today got a power steering / vacum pump off a 2nd gen. has any one tried to put one of these on there 1st gen.. they are a lil diff.
FOR SALE 1991 dodge d350 hx40 2nd gen intercooler, few pump mods, 366 spring, no afc, timing bump,pistion lift pump, 5" down pipe, bhaf, old smokey fuel pin, boost, pyro, tach gauges 14.10 @96mph 310hp, pm for pics and info..
boostedve
Postby dpuckett » Sun Dec 30, 2007 8:25 pm
I put a vane (91.5+) vacuum pump on my nonIC 91. I had to trim the lower 3" or so off the bottom of the throttle bracket, and get a vacuum pump supply hose made up (CaseIH dealer, $30 or so). Othe rthan that, it was a near direct fit.
IS your fluid foamy or have any other contamination in it?
Daniel
Postby boostedve » Mon Dec 31, 2007 1:14 pm
its not foamy while its running and both lines are new and when i put some of the fluid on my finger it still red so nothin eles is getting into it..
boostedve
Postby abledog » Wed Jan 09, 2008 7:36 pm
You may try looking at the flow control valve. It located in the pump behind the high pressure hose fitting. There's a good explination of how it works on WestTexasoffroads web site in the tech section.
Terry
1990 W250 Original owner Purchased New 10/89
92 W250 Purchased12/07 Proof of how much abuse and neglect a 1st gen trucks can take and continue to run. She's be rode hard and put up wet and in dire need of some TLC.
abledog
