Dana 80 drw to srw conversion
Postby Collers9640 » Fri Nov 11, 2016 10:15 am
Disregard
Collers9640
Re: Dana 80 drw to srw conversion
Postby DodgeFreak » Mon Nov 14, 2016 8:47 pm
1st gens didn't come with a Dana 80. If you are converting it from the Dually to a Single you need to find a single rear wheel axle because it is narrower. If the 92 was a D350 Srw then go for it.
