Rotor help
Rotor help
Postby 92cummins89 » Sun Feb 19, 2017 7:06 pm
Replacing rotors pads an calipers but I have a solid 1 in gap between the rotors an thin semi circle dust cover plate
An this isn't righ, the inner brake pad doesn't fit in the groove if this makes any sense
92cummins89
Re: Rotor help
Postby dazedandconfused » Mon Feb 20, 2017 8:19 am
More details would be great. 2wd or 4wd truck?
Re: Rotor help
Postby 92cummins89 » Mon Feb 20, 2017 8:40 pm
4x4 it won't let me upload pics
92cummins89
Re: Rotor help
Postby Rob_O » Wed Feb 22, 2017 10:49 am
Did you change *anything* other than the rotors?
Rob_O
Re: Rotor help
Postby DodgeFreak » Wed Feb 22, 2017 2:57 pm
You didn't by chance get 2wd rotors did you??
Re: Rotor help
Postby DodgeFreak » Wed Feb 22, 2017 3:05 pm
Looks like 2wd stick out farther which would be the opposite of your issue I think......is the hub seating all the way on the spindle?? did you change bearings at all??
Re: Rotor help
Postby 92cummins89 » Sat Feb 03, 2018 1:42 pm
still having this issue everything is seated right an both sides have the same gap
when the inner pad is in the grooves there is a big gap b4 it meets up with the rotor
i feel as if the rotor isnt deep enough if that makes sense
92cummins89
Re: Rotor help
Postby thrashingcows » Mon Feb 05, 2018 5:44 pm
Pics would definitely help us visualize what is going on and help you figure this out. I know when I did the front end on my W350 I bought the wrong 8 bolt rotors....they were for a 4wd, but were for the rare 8 bolt D44 front axle, not the 4500# D60. Maybe that is the problem?
thrashingcows
Re: Rotor help
Postby 92cummins89 » Tue Feb 06, 2018 12:39 pm
well i figured it out when i did my passenger side a few months ago i had to replace the axle u joint and when i went back together with it i mixed up the shaft and the piece that holds the caliper and had them swaped witch is where i was getting my gap from dumb ass moment for me
92cummins89
