rear drum brake wheel cylinder actuator pins
Postby mweiman » Fri Nov 10, 2017 6:54 am
Does anyone know where you can get the pins that connect the wheel cylinders to the rear brake shoes? Got some from Advance Auto but they would not work and have not been able to find anything searching the internet or any wheel cylinders that come with them.
Thanks,
Matt
mweiman
Re: rear drum brake wheel cylinder actuator pins
Postby thrashingcows » Fri Nov 10, 2017 1:48 pm
I did some quick searching and could not come up with those either.....guess used is the route you'll have to go. You can try car-part.com...they link 1000's of junkyards around north america....might be able to find what you need through them?
Or over on the DTR you can contact a member...Oliver Foster...he has many parts for our 1st Gen's.
thrashingcows
Postby PToombs » Fri Nov 10, 2017 6:14 pm
How about the dealer? They shouldn't cost that much.
Or a brake supply store, they have brake parts for just about any size vehicle?
Postby Philip » Sat Nov 11, 2017 9:09 pm
Call Summit and talk to them. Be sure to has the length of your pins handy in case they ask.
https://www.summitracing.com/search/bra ... inder-link
The first pin on that link shows for 11" and 12" drums.
