Wheel Interchange
Wheel Interchange
Postby mhuppertz » Thu Jan 04, 2018 9:25 pm
Lost my spare in a wood hauling misadventure.
There are always 1 ton Dodge vans in the boneyard that have 8 lugs and Dana 60's. Are they the same as a 1st gen?
MARK
'93 W250, HTT Stage IV/16cm, POD's, cut AFC pin, Pump advanced, Pyro, Boost, Fuel Pressure Gauges all non functional, burned wiring, 3/8” fuel line, BHAF on custom intake, 3,200 Spring, ARP Studs, New Head at 392K, Detroit Locker, NV4500, other stuff…
mhuppertz
Re: Wheel Interchange
Postby DMan1198 » Fri Jan 05, 2018 12:50 pm
They likely are, but measuring is a good idea. The pattern you’re looking for is 8x6.5”. Iirc dodge has never changed from that pattern (the only ones that have is ford, who went to the metric 8x170mm).
