Upper control arm
Upper control arm
Postby meby » Tue Feb 13, 2018 5:45 pm
Does anyone know if the inner bolts by the frame are supposed to drop right in the bushings? My bolts are slightly bigger than the new Moog bushings. Didn't measure, but they are off by only a couple thousands.
Can I freeze the bolts and warm the bushings or should I drill out the bushings?
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Re: Upper control arm
Postby thrashingcows » Tue Feb 13, 2018 7:35 pm
They need to spin inside the bushing so you can adjust the A-arms when doing alignments. Mopar used that same style of bushing on many different makes and models over the years. I'm guessing you got the wrong ones.
thrashingcows
