where to buy rear spring degree shims ?
Postby jethro » Fri Jul 27, 2018 2:41 pm
I am looking for a pair of 3 degree rear spring wedge shims. My springs are 3 inches wide----
so I would think I would want a 3 inch wide shim... (right?)
I just put in a gear vendor's overdrive and am correcting the pinion angle to match the
output on the GV unit.
Cant seem to find a 3 degree -3 inch …….. anyone have a source...…..
I will fire up the milling machine if I have to.... but I don't want to...… figuring out how to hold
the work down on that would be a major PITA !
Thanks ahead of time for any ideas ……..
Tim B.
jethro
Re: where to buy rear spring degree shims ?
Postby matthewh » Thu Aug 02, 2018 4:32 pm
Summit Racing or Jegs had a few options. W.F.O. Concepts may as well.
Found mainly aluminum ones, but there were a few steel options as well
matthewh
Postby bensol64 » Wed Nov 28, 2018 8:38 pm
I got mine at truckspring before, though I forgot the brand.
'92 W350 5speed 4x4 with 17" wheels and 33" ironman tires
bensol64
Postby Donkey Kong » Fri Nov 30, 2018 1:24 pm
Are there any local spring shops near you? Most will have plenty in stock and will sell cheap to you
Darth Cummins 93 CC W250 NV4500 HX35 350hp 37s 1.5T leafs...its stiff
Donkey Kong
