KTA wrote:Should be 1.5" 35 spline as far as I know, unless it was originally a gasser rear end.
KTA wrote:The ARB looks stronger than a detroit. I know of some detroits that broke pulling, but don't know of any ARB's that have that weren't the reult of not getting it all the way engaged before applying the power.
ford69557ci wrote:i run a welded d70 and drive it like a 10.5 tire drag car and still have not broke and i run water and nitrous through it when i hit the gears really hard. i have twisted i few drive shaft when launchin in 4x4 bet never a d 70 or 60
cummins king wrote:go with the rock well if you can get on at a good price then go for it, there indistructable, theres only two down sides that you should now, first is the gear ratios, i think that theres only two available, and second there 300 pounds more the a dana 80, the weigh one is not to big of a deal, and you can send then to a offroad shop and get them to shorten then and put stronger nuckels and axel shafts in them
good luck!
nooblet wrote:Its a top loading axle. You would have to lift your truck atleast 6 inches, probably more lol...
Get a 14-bolt
Chris
ford69557ci wrote:it is actually not bad on the street i run boggers or geolander mt's and they wear fine some parkin lot situations will get some tire squeal but not all the time i have my front welded to make for some interesting fun with 4x4 launches. if it still ran lol
mhuppertz wrote:ford69557ci wrote:it is actually not bad on the street i run boggers or geolander mt's and they wear fine some parkin lot situations will get some tire squeal but not all the time i have my front welded to make for some interesting fun with 4x4 launches. if it still ran lol
My spiders are probably splattered all over the housing. It's snowing so I lost my motivation to pull the cover...
Dude, you are hard core! I just couldn't do the welded spiders on the street. How the heck do you steer in 4x4 with a welded front diff????
