What's the tallest tires or lift kit?
Postby eyoung429 » Thu Jan 04, 2007 2:46 pm
That I can fit on my '91 W350 Dually all the way around and still be able to haul a "decent" load with? Or can I buy a lift kit for this rig? I am 6'5" and this truck is shorter than my '97 F150 stock.
Thanks!
1991 IC D350 2wd Dually,st cab, full 4in Magnaflow exhaust, 3.73 gears, auto 518,HX35....goin' to twins!!!
member of the cable pull club
eyoung429
Postby KTA » Thu Jan 04, 2007 5:45 pm
Do you mean on stock rims?
Postby eyoung429 » Thu Jan 04, 2007 8:59 pm
Unfortunately yes, unless there are some factory stock aluminum rims that will fit (doesn't matter if they are GM, FORD or Mopar just as long as they are not import crap).
eyoung429
Postby KTA » Fri Jan 05, 2007 7:11 am
235/85 R16 is the standard biggest on stock rims. You can go to a 255/80 R16 if you can find them in the tire and tread you want, but they will rub in between the duals when loaded. Both of these tires can be found in sizes of 31-31.5" tall.
Postby eyoung429 » Fri Jan 05, 2007 7:32 am
Cool. I have 225/75R16 on her now but will find another set of rims to have as daily cruisers and keep this orig set for haulin'.
What other stock factory rims will fit this year of dually's?
eyoung429
Postby wannadiesel » Fri Jan 05, 2007 5:02 pm
Fords will fit but you may not be able to get them to stop bouncing.
Our wheels are not hub-centric or lug-centric. :roll: The owners manual says to get 2 tapered lug nuts and use them to center the wheels.
Best dyno: 408/844
wannadiesel
diesel guru
Postby kiszka6911 » Fri Jan 12, 2007 12:42 pm
I have 235-85-16 firestone M/T which are 32" tall. That coupled with the 2" skyjacker lift springs has my truck pretty tall. I will get some measurements, door sill to ground, front fender to ground so we can compair.
Anthony Kiszka. MI 1993 W350, 3.5" flowmaster exhaust, BD+60 injectors, OSFP, 3200 GS, westach BST & EGT. HTT Stage III, 16CM housing. BHAF, airflo elbows, Skyjacker springs, Buckstop bumpers, Firestone M/T 235-85-16 tires, PIAA fogs, H4 conversions.
kiszka6911
Postby eyoung429 » Fri Jan 12, 2007 2:03 pm
Cool....that would be nice...
eyoung429
Postby kiszka6911 » Sat Jan 13, 2007 6:17 am
39" from driveway slab to front fender lip
42" from driveway slab to rear fender lip
25" from slab to driver door sill plate
I guess I should have put on the 4" skyjacker front lift springs. The extra 2" would have nearly leveled the truck!
kiszka6911
Postby dpuckett » Sat Jan 13, 2007 12:32 pm
Going to 235/85-16s will give you about 2" more height over your 225/75-16. I cant believe a W350 of any sort would be shorter than a stock F150- those things were pretty low for a 4x4 werent they? But I wont call you a liar, it's just hard to imagine.
They are hard to find, but you can get 9.00 16s for the truck. Something like a 100 aspect ratio. Might make it a little unstable.
19.5s are another option.
DP
Postby drcom » Mon Feb 18, 2008 4:26 pm
Since I have single wheels (not dually) and want to stay with the 16" rims, what would be the tallest tire in inches that would fit without rubbing? '
33" 35"
I think the 285/75R16 BF Goodrich are about 32" but I would like to go a little taller....maybe 35, but dont want to do a lift. Thoughts?
drcom
Postby LOGANSTANFORTH » Mon Feb 25, 2008 7:22 pm
eyoung you can run a set of 255/85/16 BF Goodrich's MT's for about 175 a tire..........34x10.50x16 Super Swamper LTB's for about 140 a tire...........34x9.00x16 Super Swamper TSL's for about 160 a tire...........32x9.00x16 Super Swamper TSL's for about 140 or the 10 plies for about 170............33x10.50x16 Super Swamper TSL Radial's for about 195 a tire.............265/80/16 Super Swamper TSL Radials for about 165 a tire............255/85/16 Super Swamper Truxxus MT's for about 145 a tire.............35x10.50x16 Super Swamper Bogger 10 ply's for 235 a tire.............38.5x11.00x16 Super Swamper Bogger's for 250 a tire.........
thats all the tires i could find right now that will fit, some might require spacers between the duals......personally i would go 6 inches and 38x11.00x16 Boggers.......
THEY PUT THEM ON A PLANE TO SOME STRANGE AND FOREIGN LAND, THEY SAID GOODBYE TO MOM AND DAD AND HELLO TO UNCLE SAM, THEY NEVER THOUGHT THE DAY WOULD COME WHEN THEY MIGHT HAVE TO KILL A MAN, THEY DID NOT SLEEP A WINK THAT NIGHT BUT THEY WON FOR UNCLE SAM
LOGANSTANFORTH
Postby eyoung429 » Wed Feb 27, 2008 6:50 am
Cool, will have to look into some of those.
eyoung429
Postby GO OVRIT » Sat Mar 01, 2008 7:56 pm
The dually I've got has 235/85s on it and towers over them with 2" of lift. A lot of guys around here are running 305s and even 315s on stock rims with spacers, but in my opinion, you get too much sidewall roll. I even worked on a superduty with 6 39x13.50x16 super swamper iroks on 16x6 aluminum rims. It drove horrible.
GO OVRIT
