Right Headlight Gound????
Postby mhuppertz » Sat Apr 19, 2008 7:02 pm
Looking through the FSM I found there are several things connected to the "right side headlight" ground other than the right side headlight.
I just found out that the right side headlight ground is connected to the leftside ground (redundancy?).
I have a harness on the right front that is split out three ways, one to the side marker, one to the turn signal, and the other just laying down there not connected (but is stripped on the end).
Can somebody take a look at their harness up front and tell me if that third bundle is connected to the headlight ground???
Thanks,
Mark
mhuppertz
