About 3weeks ago the power steering started getting grumpy in the mornings. For the first 3-4 miles instead of gently turning to the left or right it would lurch or jump to the left or right. It would also have about 1/2 a turn of play in the steering wheel before it would do anything in either direction. After those 3-4 miles everything would tighten back up and go back to normal. It got worse, much worse. To the point of throwing the truck off the road or into the other lane.
First i started off by checking all steering joints..draglink, etc. Everything seems to be fine. Then i check the ball joints and wheels bearings...they were ok too, not a bit of play. Next i checked the steering shaft, its a borgeson and it was tight as a new one.
So next i put a new steering box on it...also checked mounting plate....it was fine. The new box seemed to help it for the first couple days then it went right back to the way it was. Jumping and lurching. I also ended up loosing power steering completly, it turned out to be the pump. Shes got a new one of those now. It still jumps and carry's on...any help would be greatly appriciated. All parts came from NAPA. I think its the gearbox but i cant see a new one going bad in two days like that.
Sorry for the book and thanks for your time!
