Front brake splash shields are kicking my butt.
Postby Begle1 » Sat Jul 12, 2008 12:51 pm
I get the new rotors installed on the hubs, press on the wheel studs, get the bearings packed full of grease, install the seals, slide the hub onto the spindle...
And the rotor scrapes against the splash shield. I bend the part of the splash shield that is scrapeing, and that makes another part scape. I do that for twenty minutes, then I take the splash shield off and pound it flat with a hammer, and it still scrapeing when I put it back on.
Anybody else ever get their butts kicked by these flimsy pieces of huh??
And, more pressingly, is it that bad of an idea to run without them, like I'm doing now?
Postby Begle1 » Mon Jul 14, 2008 1:04 pm
What is the idea behind the splash shields? I imagine that the major thing they do is keep rocks and other debris from damaging the rotor?
Postby gear jammer 91" » Mon Jul 14, 2008 9:32 pm
It's the middle of summer, who needs splash shields. When it starts raining again just duct tape some tin foil to the back of your wheels, it should keep the water out. :lol:
01 LB7
gear jammer 91"
Postby mprmn08 » Tue Jul 15, 2008 3:34 pm
the splash shield actually keeps the brakes allot cooler. if you tow or do alot of stop and go driving i would deffinatly try to keep them on there.
mprmn08
Postby GO OVRIT » Tue Jul 15, 2008 6:42 pm
I've run my Jeep without them for years, to keep mud from packing in between. I guess if the heat is an issue you should run them though. Did you check the new rotors to see if they are the same width? I've gotten some rotors before that in my opinion were nowhere close to factory specs.
GO OVRIT
Postby greasemonkey » Sat Aug 16, 2008 10:57 pm
begle I had that happen to me when I changed the rotors on my dad's 91, drove me crazy trying to tweak and straighten them, left one side off, the other side squeaks now and then with the right amount of brake pressure. only thing I could find was the ID of the rotor was slightly smaller, just enough to rub on the dust shield.
we've been way too busy to jack it up and take another look at it. I guess I'll probably be playing the same stupid game when I change the pads/rotors on mine here pretty soon.
'93 250 4x4 NV4500, flatbed, club cab, ex brake, pump tweaked, too many new ideas thanks to you guys.
dubbed the "Mexican Mtn Goat"
..if you find yourself in a fair fight you did not properly prepare..
..hot rodders are the original recyclers!..
greasemonkey
Postby MMiller » Sun Aug 17, 2008 7:04 pm
I pulled mine off of all my trucks, as they get full of mud and then squeal like crazy when the mud dries up. They have been off my 93 for at least 100,000 miles, and I still have the original rotors at 250,000 miles. This winter I plan on new front brakes, rotors, and such. The dust shields will still not be installed. I've noticed no ill effects of removing the piece of tin.
Michael
MMiller
