Philip wrote:If your talking about the using them on the rear axle. The axle housing is to short for a set of dually rims. The tires will hit the springs. With a stock offset dually rim you would need at least 3/4' of spacers to get the tires off the springs.
If found this out after I bought my truck. One of the PI's (previous idiots) had replaced the axle with a SWR axle and used 5/8's washers to clear the springs.
