Drum brake help.
Drum brake help.
Postby Dieselhick » Thu Dec 18, 2008 1:09 pm
Hi, im new to this website and this is the first time doing brakes on a 1st gen. I have a 91.5 2wd drive with the 12 inch drums. i went to napa to get new drums because mine are rotten and look like they havent been used in years. But the guy at napa asked me if my drums were 3.77", 3.91", or 4.5", does anyone know what this number is refering to and what would be on my truck. Any information would be greatly appreciated.
Dieselhick
Postby dpuckett » Thu Dec 18, 2008 7:09 pm
Should be 12x3 for the drums, regardless of what shoes are actually in it.
Daniel
Postby Dieselhick » Thu Dec 18, 2008 8:49 pm
We got that far but there were three choices of 12" drums, 3.77", 3.91", and 4.5". It didnt say what these numbers were refering too. All i can think of is the axle seal diameter, its the only thing around 4 inches (3.98").
Dieselhick
Postby Philip » Thu Dec 18, 2008 9:53 pm
He is asking about the center of the drum that slides over the inside of the hub assy.
I don't know the size to help for your truck. Mine is a dually so the hubs are different. Same with the brake drum.
Postby Dieselhick » Fri Dec 19, 2008 10:20 am
thanks for the help
Dieselhick
Postby Dieselhick » Fri Dec 19, 2008 10:41 am
Would a set of drums from NAPA have studs already in them or do i have to press new ones in myself?
Dieselhick
Postby dpuckett » Fri Dec 19, 2008 5:43 pm
I just reuse the old studs if they arent mangled up. Use a drift punch to seat them in the hub.
Philip- not to argue, but in my experience, the drums have all been the same on the 3/4 and 1 tons. Hubs were different, but the drums all interchanged. I havent owned that many 3/4tons, though.
DP
Postby Dieselhick » Sat Dec 20, 2008 6:47 am
okay sounds good, thanks for the help guys.
Dieselhick
Postby Dieselhick » Sat Dec 20, 2008 7:24 am
So i went and measured the opening in my drum and it was just over 5 inches. The problem is this isnt one of the measurements i was given at NAPA the largest number he gave me was 4.5 inches.
1991.5 D250, Auto, 2wd
Dieselhick
Postby Dieselhick » Sat Dec 20, 2008 7:25 am
And i dont think he would want to order all 3 sets in for me.
Dieselhick
Postby dpuckett » Sat Dec 20, 2008 10:31 am
Do you have a CarQuest nearby? If not, I have a spare set of drums, turned and ready to go .
DP
Postby Dieselhick » Sat Dec 20, 2008 1:18 pm
Ya I have NAPA, Carquest, and Benson auto parts here locally. I'll try Carquest on monday.
Dieselhick
Postby Dieselhick » Mon Dec 22, 2008 8:43 am
So i went to carquest and they gave me the same numbers. I got them to order the 4.50 but their probly wrong.
Dieselhick
Postby SChandler » Tue Dec 23, 2008 2:11 pm
I got these part numbers off of Rock Auto's website (http://www.rockauto.com/catalog/raframecatalog.php): BENDIX Part # 140547 and WAGNER Part # BD60328. You could try having your parts guys cross reference the part numbers and see if that narrows down the selection. I haven't had to order drums yet, but those ones on the website only list one part number for all of the 3/4 and 1-ton trucks from 81-93.
SChandler
Postby Dieselhick » Tue Dec 23, 2008 4:37 pm
Thanks for the info but it turns out the rear drums in my truck were the same ones that are used on a certain axle that finished production at the end of 1990. So none of the heights that I was given by either of the stores were correct, the height of my drums were over 6 inches. So either the Dana 70 in my truck has been swapped out for another sometime in its past or i just got one of the rare 1991.5 that had this brake setup. And it took me over a week to figure this out.
Thanks for the help guys.
Dieselhick
