U joints??
U joints??
Postby hummin cummins » Mon Feb 12, 2007 3:26 pm
I just replaced the driveshaft ujoints and there is still a squeak coming from underneath the truck. When i was putting the new ones in i noticed that there was some play in the transfer case. is that alright? the truck vibrates as i drive down the road and it also squeaks. I have a 250 4x4 truck.
Cummins 250 bd xxx injectors, stage iv/18, bhaf, fuel pin, 3200 gsp, valet swtch, isspro tach, autometer pyro and boost, full screw turned up
hummin cummins
Postby hummin cummins » Tue Feb 13, 2007 7:57 am
this morning i put the old girl in 4wd and it drove smooth cruising down the road almost no vibrations. the only thing is when i turn corners even if they are not that sharp she really gets to hopping
hummin cummins
Postby mojo » Tue Feb 13, 2007 11:33 am
If memory serves me...
Block wheels, Jack up front end, put transfer case in neutral, lock front hubs, turn steering wheel all the way to stops, try to rotate the wheels by hand.
If the wheels rotate hard an axle joint needs to be replaced. This might be it and if I missed anything someone please chime in.
Joe
mojo
Postby Cschafer » Tue Feb 13, 2007 8:28 pm
The transfer case should have a little play. The front axle u-joints will clatter like a horse on pavement if they are really bad. You can check them by jacking up the wheel, jambing the axle shaft with somthing and rock the tire back and forth while watching the joint. If there is any play it is bad and if it is greasable this is the time to do it. If both front wheels are getting good traction while turning at all it will tend to hop. Check the front driveshaft cv joint for noise making. Grease everything you can and go from there.
91 w250 wrecker
Cschafer
Postby hummin cummins » Tue Feb 27, 2007 5:34 pm
Carrier bearing went out and also the u joints in the front end...
hummin cummins
USE YOUR NOSE
Postby BEARKILLER » Thu Mar 01, 2007 4:07 pm
:idea: The first indication of a carrier-bearing going bad is a "burning rubber" smell after a drive.
What this smell is is the bearing hanging up and spinning inside the rubber holder.
If a carrier is suspected, drive for several miles, then set the brakes, crawl under, and check the carrier rubber for smoke and smell. :twisted:
:arrow: Don't run over yourself, while performing this experiment.
#4 = 1991 D-350 LE Getrag
BEARKILLER
Re: USE YOUR NOSE
Postby TWorline » Thu Mar 01, 2007 6:01 pm
[quote="BEARKILLER :arrow: Don't run over yourself, while performing this experiment.[/quote]
Hey good tip, is this from personal experience, I see you have a 5 speed. :D
Tim Worline
http://www.CoolerTubz.com/
TWorline
Re: USE YOUR NOSE
Postby Begle1 » Thu Mar 01, 2007 8:59 pm
BEARKILLER wrote:If a carrier is suspected, drive for several miles, then set the brakes, crawl under, and check the carrier rubber for smoke and smell. :twisted:
I don't exactly know what happens when the carrier goes bad; I guess it would create a lot of vibration in the driveline and start eating U-joints.
The carrier is two concentric metal rings attached together with inch-thick slotted rubber. My truck had eaten the rubber; I never noticed a smell, just a "clunk" under hard acceleration (and my truck can hardly accelerate as it is).
Anyways, easiest way to check for a bad carrier bearing is to either look at the rubber or push up on the driveshaft. If you can push the shaft up an inch, then the carrier's bad. It shouldn't have an 1/8 inch of play.
Postby hummin cummins » Tue Mar 06, 2007 10:53 pm
found out it is the bearing on the output shaft toward the front of the truck on the transfer case... anyone ever do this fix?
hummin cummins
Postby g1625s » Mon Mar 12, 2007 4:59 pm
not too much to it. Pull the d-shaft, yoke, extenssion housing/bearing retainer and the bearing should just come out. I think they're about 50 clams.
presently-'96 4x4 2500
formerly-'89 W350
g1625s
Postby PToombs » Tue Mar 13, 2007 2:38 pm
The voice of recent experience right there! :lol:
Postby Dean » Tue Mar 13, 2007 7:42 pm
My carrier bearing failed just last Sunday. I had the burning rubber smell. I thought it was the city I was driving thru. But the noise and vibration got worse and I knew it was the shaft. So I got out and saw the smoking rubber.
I took it apart and what a POS bearing. It only lasted 3k miles. So I ordered a pillow block and I am going to install that so my carrier bearing should out live me.
Dean
Dean
92 W350 5 speed, F-450 rear frame sectioned on with Dana 80 rear, 370 injectors, HTT stage 4/16cm, Pump and timing bump, Hydro disk brakes, Porsche e-brake, Small sleeper for my dog, Alu flatbed.
Dean
