Fuel tank leak.
Fuel tank leak.
Postby Heo » Sun Jan 25, 2009 9:35 pm
The fuel tank on my 92 leaks when it try to fill it to the brim. Once a few gallons have been used the leak goes away ( duh , but Im just trying to give all the details). The previous owner installed an auxillary tank in the bed and I assume that it ties into the stock tank around the filler neck..
So is there a connector for the filler neck to the tank that could be old and cracked.. Its been a little cold to go poke around under the truck..
Thanks!
Heo
Postby Ace » Mon Jan 26, 2009 7:31 am
Tighten up the pickup/sending unit. Rightey-tighty, lefty-loosy.
Ace
Postby mprmn08 » Mon Jan 26, 2009 4:00 pm
stick your lighter under there and see if you can see anything. :rock: just make sure someone video tapes it :popcorn:
mprmn08
Postby PToombs » Mon Jan 26, 2009 6:42 pm
mprmn08 wrote:stick your lighter under there and see if you can see anything. :rock: just make sure someone video tapes it :popcorn:
OH, that's just not right! :shock: Good thing it's not a gasser! :lol:
I'd bet on the sender too. If it was the neck, it would leak outside the frame where it's easy to see. You may have a cracked fitting under there.
Postby GO OVRIT » Mon Jan 26, 2009 9:19 pm
Most likely its what Ace and Pete said, but it could also be the big grommet around the filler pipe. Another not-likely possibility would be a broken vent.
GO OVRIT
