Master cylinder gone south AGAIN
Postby Makaio » Sun Feb 08, 2009 1:50 am
I am having major problems with my master cylinder. This is the THIRD time it has failed on me. They are all new in the box, from NAPA, and made in Italy, if that makes any difference. They all lasted about 3 to 4 months and then the pedal gets soft or the brake light comes on. It's fine when newly installed. Pedal is rock hard. No leaks anywhere either. Should I just get another through warranty or buy another brand? I'm on a rock so parts stores are limited. We have NAPA, Carquest, Checker and the Dodge dealership. Possibly a bad run of master cylinders? Is the heat killing the seals? I am dead ended.
Matt
1992 W250 auto, ASA/AFE intake, H1C hybrid 60-16, Bosch 190's, Bully Dog fuel pin, 366 spring, modified pump and a 4" turbo back exhaust. Suncoast valve body plumbing 3.54's w/LSD. Autometer gauges.
Makaio
Postby burnt_servo » Sun Feb 08, 2009 4:43 am
what fluid are you running in them ?
'93 w250 .... stock ...
burnt_servo
Postby Renigade » Sun Feb 08, 2009 5:22 am
Love your avatar Man
I wandering also what type of fluid are you using.
1993 1st gen BHAF -Smoke screw 2.5 turns, star wheel 2.5 turns. Fuel screw 1.25 turns, fuel pin ground.
Renigade
Postby Makaio » Sun Feb 08, 2009 11:01 am
burnt_servo wrote:what fluid are you running in them ?
I can't even remember what I put in it. I think it was the NAPA brand Dot 3 or Prestone Heavy Duty. One of the two. :?
Matt
Makaio
Postby Makaio » Sun Feb 08, 2009 11:08 am
I didn't even think about the fluid I put in it. I just bought the cheapest DOT 3. Is there a preferred brand that can better handle the heat from our engines?
Matt
Makaio
Postby burnt_servo » Sun Feb 08, 2009 2:28 pm
i was thinking that maybe you had like a 5 gallon pail of brake fluid that you where using for all the master cylinders ...... that may have become contaminated .
maybe you need to closely look at the rest of your braking system , maybe the master cylinder isn't going bad , but something else is causing spongey brakes.
burnt_servo
Postby Makaio » Sun Feb 08, 2009 11:10 pm
Well, there are no leaks anywhere and when I did install a warrantied master cylinder with a new one, the pedal was rock hard again. Then after 3 or 4 months, the soft pedal came back. I also bypassed the ABS valve and went with a solid line.
Matt
Makaio
