Front Axle Swap
Front Axle Swap
Postby ryanihf250 » Tue Feb 17, 2009 7:47 pm
I have a friend that is willing to Swap his front axle out of a 85 W-350 that has 4.10 ratio for mine that is a 3.55. I need to 4.10 to match my Dana 80. It will save me some money. Will this swap be a simple swap over since they are both Dana 60s. Steering and everything should be the same right?
Just making sure this is doable before I attempt it.
Thanks
Ryan
Playtoy:1992 Dodge 350 4x4 SRW Cummins. 6in lift, 35in Pro Comp X , Dana 80 swap 4:10 Pump maxed, BHAF, 6x16inj, 3200 GSK, Piston Lift Pump, II SPS turbo.Street Pulling truck project. www.libertyantiquetractorpull.com
ryanihf250
Postby gear jammer 91" » Tue Feb 17, 2009 8:01 pm
I think it should be a straight swap. I don't think dodge changed much on these trucks from the early 70's till 93.
01 LB7
gear jammer 91"
Postby peobryant » Tue Feb 17, 2009 8:07 pm
gear jammer 91" wrote:I think it should be a straight swap. I don't think dodge changed much on these trucks from the early 70's till 93.
Based on the very few changes that Dodge put in place over the years, I also think it should be pretty straight forward.
Postby GO OVRIT » Wed Feb 18, 2009 4:26 pm
The 85 has the less desirable Selectro lockouts on it, but it should bolt in just fine. Personaly, I'd probably just swap the gears with him. Its a little more "technical" work , but less "grunt" work. :)
GO OVRIT
Postby mprmn08 » Wed Feb 18, 2009 4:57 pm
i agree with go ovrit
mprmn08
Postby peobryant » Wed Feb 18, 2009 5:05 pm
Just curious, but won't the '85 have a 4.10 front, and 3.54 rear? Is your friend planning on getting another rear axle?
Postby PToombs » Wed Feb 18, 2009 6:02 pm
'91 Cummins wrote:Just curious, but won't the '85 have a 4.10 front, and 3.54 rear? Is your friend planning on getting another rear axle?
Trouble maker! :shock:
Postby ryanihf250 » Thu Feb 19, 2009 8:05 pm
He is swapping out his Dana 70 from 89 Dodge that he totaled it has 3.55 ratio. We are also going to swapp locking hubs.
So this will be a win-win situation if this works well! :D
ryanihf250
Postby nooblet » Mon Mar 02, 2009 4:41 pm
ryanihf250 wrote:He is swapping out his Dana 70 from 89 Dodge that he totaled it has 3.55 ratio. We are also going to swapp locking hubs.
I could be wrong, but I believe the hubs are not the only difference in the axles. I think they have different shafts also.
Chris
nooblet
Postby ryanihf250 » Mon Mar 02, 2009 5:40 pm
The hubs were the only thing different. Axle shafts are the same. The 85 year model hubs were like selectomatics. It also had Cast flange to hold the selector on which I did not like, so we changed them out with no problems just took a little time. The swap went very good. We both got what we needed without spending money and very little difficulty! :D
ryanihf250
