rear diff angle
rear diff angle
Postby Mad Max » Sun Feb 22, 2009 8:07 am
Fellas - what do you think of my rear diff angle?
I've got it overfilled by ~1.5 quarts to get fluid up to the front bearing, and while I can't confirm it is getting oil I'd like to get your opinion.
I also have no choice on the angle - it has to be this steep in order to aleviate vibration. There is a big CV joint on the other end coming from the t-case, and I have zero vibration - none at all. So my angle is good but I'm trying to determine if the front bearing is doomed?
If it is, what can I do to get fluid up there? External lube port from the back? I can do that....
Thanks,
- Sam[/img]
"...there's always a way".
'78 W950 Power Wagon "Bud"
'85 W350 Crew "Big Mack"
Mad Max
Postby Richie O » Sun Feb 22, 2009 9:54 am
I fixed your picture link so it would work for ya.
Postby dnrcustoms » Mon Feb 23, 2009 7:56 pm
Depending on your highway driving, I would say it won't be long... Its like like you are dead even... I always set them up with like 2-3* down in relation to the driveshaft angle.... So I think you could afford to drop it a little... When your under acceleration now, I bet your pinion angle is actually inverted....
dnrcustoms
Postby KTA » Mon Feb 23, 2009 7:58 pm
Put a cv on both ends and you can fix your angle, problem solved. 8) :P
Postby redneckroot » Mon Feb 23, 2009 8:17 pm
On our race cars we had a remote reservoir and filled the rears full, it would allow fluid to flow in and out of the rear as needed.
We did this because the wide 5 hubs would fill with oil as we went around the corner. But it also allowed the fluid some place to go as it heated and expanded. But I also think you could drop it down a ways.
redneckroot
