Steering box bracket question.
Postby merkerguitars » Sun Mar 01, 2009 2:05 pm
So my dads truck is finally out of commission. The frame is cracked and the bracket is destroyed pretty bad. I called the local dodge dealership, he told me the proper part no. for bracket was 4447405 ,which turned out to be the reinforcement bracket :( I heard the proper part number is 4447405 btw his truck is a 1993 Dodge W250 4x4 w/ cummins engine.
Here is his old bracket.
merkerguitars
Postby Philip » Sun Mar 01, 2009 2:45 pm
#52037876 its around $20 or so.
Postby PToombs » Sun Mar 01, 2009 6:12 pm
You'll want the reinforcement bracket too. Every little bit helps! ;)
Postby peobryant » Sun Mar 01, 2009 8:26 pm
PToombs wrote:You'll want the reinforcement bracket too. Every little bit helps! ;)
If Pete is saying you need to spend extra money, than it is probably a good idea. ;)
I do happen to agree with him though.
Postby merkerguitars » Sun Mar 01, 2009 9:48 pm
Already picked up that reinforcement bracket accidentally. I thought I ordered the correct part the first time, but at least I'll have both.
merkerguitars
Postby peobryant » Sun Mar 01, 2009 10:33 pm
merkerguitars wrote:Already picked up that reinforcement bracket accidentally. I thought I ordered the correct part the first time, but at least I'll have both.
Yep, it's a good thing too. Can never be to safe.
Postby PToombs » Mon Mar 02, 2009 6:19 pm
You might want to look around on some of the diesel sites. There is some good info on boxing the frame to prevent that from happening again. ;)
Postby SChandler » Thu Mar 05, 2009 3:43 pm
How much was the reinforcement bracket? I'm thinking I should put it on my truck since I like to take it off road.
SChandler
Postby Bogie » Thu Apr 02, 2009 2:22 am
The New box bracket is slightly thicker then the original. As for the reinforcement bracket is being reproduced by Dodge Connection @ $48.00
For a How To on boxing the frame at the box see this link to Ramcharger Central
1984 Dodge W350 Crew Cab 9"Lift 37" SSR's 360/NP435 D60's W4.10's
1966 Dart 273HP 4Speed 3.90's Radio/Heat Delete
Bogie
Postby SChandler » Thu Apr 02, 2009 8:42 am
Bogie wrote:The New box bracket is slightly thicker then the original. As for the reinforcement bracket is being reproduced by Dodge Connection @ $48.00
Thanks for the links. That's some good info.
SChandler
Postby Ace » Mon Apr 06, 2009 7:33 am
The problem with the steering box mount on these trucks is there's not much lateral strength to the frame at the mount there. The C-channel is connected to the crossmember on the bottom and that's it, so there's little strength to the frame in the neutral axis. The frame wants to give in/outward from the top because that's the path of least resistence in the design whenever steering force is applied against it. The slight flex caused by that in this area of the frame over time is what eventually chews up the mount.
Just boxing the frame there will help, but it's not an ideal solution from an engineering standpoint. It needs gusseted to the crossmember or that brace thingy installed so it has some leverage against steering stress:
http://stuff.is-a-geek.net/PhotoAlbum/C ... TD_120.jpg
Ace
