rusted cab mounts how to fix
Postby dieseljack » Fri Mar 20, 2009 3:20 am
My cab mounts are starting to rust out. I would like to fix them,any ideas would be great. if posted in wrong area my bad but I still need help
1991 w250 rebuilt auto 170xxx Straight 4" turbo back dennyt stage2 fuel pin pump turned up 1/4 from bad new era 370s
dieseljack
Postby Richie O » Fri Mar 20, 2009 7:43 am
Find a donor cab with good mounts. I cut the mounts, floors, inner and outer rockerpanels out of a reg cab in 1 piece and welded them back into a club cab. The floors were the same from the seat mounts forward. The only difference was the trans hump. The 2wheel auto trucks have a smaller hump.
Donor cab
This is all that was left of my cab mount and floor on the drivers side.
Cab with floors, rockers cut out.
This is where I joined old and new
All done
Postby PToombs » Fri Mar 20, 2009 4:52 pm
Rich, the right side is off a little bit. I think you should cut it out and adjust it to where it should be. ;)
Dieseljack, if you have most of the mount left, you can cut it out and make one, or have it made.
I bought a donor cab and swapped the whole mess. Too much like work! :cry:
Postby Richie O » Fri Mar 20, 2009 5:18 pm
I know Pete. I was surprised at how close they were though.
The easyiest solution is to find a cab that is bolt on and go complete with the correct wires. I had the cab and there was no way I would find a good extended cab's cab up here in rust world. I figure my time is free. ( I know its not ).
Postby dieseljack » Sat Mar 21, 2009 3:35 pm
Thanks I think I'm going build my own. Most of the donors I find are worse than mine. Frankenstien could learn from you guys. Jack
dieseljack
Postby PToombs » Sat Mar 21, 2009 6:25 pm
Good luck! Post pics, we like 'em! ;)
He shoulda used more power on the monster. JMO. :lol:
Postby dieseljack » Sat Mar 21, 2009 8:55 pm
As soon as I stop working 7 days a week I'm going to start. Can't wait to fix her up. Thanks for the pic good stuff. Jack
dieseljack
