Like the title says- how do I go about getting the rollpin out of my old carrier, so I can take the spider gears out and put them in my new carrier? I have broken 2 punches (Crapsman, so at least I can get new ones), plus put a chunk of steel in my hand to boot. It is not moving. Would heat from a torch work to loosen/ soften it? I have an extra set of gears with 35spline side gears (truck has 32spline), so if I have to sacrifice the big pin to get the side gears, I will.
How about forging a punch from S7? The punch appears to be spring steel or something similar. I have broken off the tip of my pritchel (used to punch nail holes in horseshoes) enough to know the Crapsman punch isnt S7. I have a couple feet of that, and a forge.
Daniel
