Steering Play
Steering Play
Postby 90FIRSTGEN CUMMINS » Sat Apr 11, 2009 3:30 pm
I just got my truck back from the shop where I had a new steering box installed, all the other front end stuff checked out, stabalizer added, shocks put on and it lined up. The problem i was having was play in the steering and although all this helped there is still a little play in the front end. is there anything else you can suggest. thanks
1990 W250 Non I/C, Mostly stock,4 inch Ex,Fuel Screw Turned Up a Little, 727TF, 366 spring, BHAF, Borgeson Steering Shaft, Under-bed B & M transmission cooler, head lights now on relays(just added)
90FIRSTGEN CUMMINS
Postby RumbleFish » Sat Apr 11, 2009 7:34 pm
check the steering shaft
