Swapping auto for 5 speed - cab issue???
Postby Diesel Nut » Sun Apr 19, 2009 10:51 am
Since I know several of you have done this swap, can you answer this - is there a difference in the floor boards between auto and stick trucks? I have a line on a good deal on a getrag for the 91.5 parts runner and want to put it in, but I have heard something on the floor boards is different. Ideas?
2006 Dodge 2500 4x4
1991.5 250 Reg cab - Parts Runner
1990 350 Reg cab - Wants to be fast
www.dieselnut.com
Amsoil Dealer
Diesel Nut
Postby Richie O » Sun Apr 19, 2009 11:41 am
If it is a 2 wheel peel auto then the cab will have a smaller hump. All 4wheel peel trucks had the same bigger hump like the 2wheeler's with the rag. You would think they would have stuck with on tool in the assembly line instead of 2 different sizes. :roll:
Postby Diesel Nut » Mon Apr 20, 2009 11:22 am
yes, its a 2wd. So, the smaller hump, will it cause issues with fitting the 5 speed?
2006 Dodge 2500 4x4
www.dieselnut.com
Amsoil Dealer
Diesel Nut
Postby lincoln » Mon Apr 20, 2009 11:31 am
Yes but you can cut the humps out and swap.
1992 W250 Single cab 5spd (stock)
1993 W350 Ext. cab drw 5spd (stock)
lincoln
Postby PToombs » Mon Apr 20, 2009 4:58 pm
I can tell you that the smaller hump won't clear the trans. I swapped humps when I did my cab swap. Not that bad of a deal. Cut the donor cab hole small, and the large hump oversize. Then you can trim the 2 to fit.
