My first post to 1stGen.
I'm keeping two 1st gens alive, a '93 D250 auto and a '92 D350 Getrag (Big Red) So, I'm glad I found this place.
Last week I had a new set of tires mounted on the front of the 1 ton. As I was backing out of the tire store lot the right side lower ball joint seperated just as I braked. Lukily, I was only traveling at a walking pace. This could have caused a fatal accident should it have happened at hwy speed.
Prior to the old gal showed no signs of front end issues beforehand. I had replaced the balljoints about 35K miles ago, tires were wearing even, kept it lub'd...
The balljoint failure appears to be due to a defective part. I have the old part cleaned up and will get some pictures of the failure.
The quality of parts (China?) these days concerns me.
I now need to replace the brake rotors as the right side rotor was damaged by impact with the lower control arm.
Can anyone here give me a good source for rotors? Last two I bought for the D250 from the local Carquest had "China" on the box. I hope they hold up better than their balljoint.
Thanks,
Dan
