by TRENDZ » Mon May 04, 2009 8:46 pm
Does anyone know the cut off date for the frame/box change. I had a 90 d250 with angled center supports in the frame arch area. I have a box from a 93, and these supports are flat. I have read elsewhere, that a 90 would have the flat supports. what gives???
