Dually brake drum- Price versus Quality
Postby 93wuntun » Sun Aug 02, 2009 10:05 am
Just shopping around and cant help but notice the huge price disparity, anyone have any personal experience with any of the following?
From NAPA...
this one costs $$$
Item#: UP 6401417
Price: $194.00
tax and shipping not included
Attributes:
Features & Benefits:Castings Meet Sae J431/g3000 Specifications For Proper Tensile Strength.
Features & Benefits:Machined To Control Perpendicularity & Run-Out For Optimal Performance & Brake Life.
Features & Benefits:NAPA Brake Drums Are Vehicle Specific & Meet Federal Safety Standards.
Product Features:NAPA Brake Drums Provide Consistent Quality & Reduced Noise.
Drum Type:Brake Drum
Mounting Type:C
# of Bolt Holes:8
Bolt Circle Diameter:6.5"
Inside Diameter:12"
Maximum Discard Diameter:12.09"
O.D.:14"
Brake Drum Surface Depth:3.56"
Height:6.29"
Includes ABS Inner Sensor Ring:No
AND this one costs less than half as much...w/ an identical description
tem#: NB 4401417
Price: $79.99
Attributes:
Mounting Type:C
# of Bolt Holes:8
Inside Diameter:12"
O.D.:14"
Height:6.29"
Includes ABS Inner Sensor Ring: NO
From AUTOZONE - Duralast
Duralast / Brake Drum - Rear
For your 1993 Dodge Truck D350 1 ton P/U 2WD 5.9L Turbo Diesel 6cyl
PRICE $70.99
Part Number: 8892C
Weight: 40.6 lbs
Warranty: 2 YR
Application: With dual rear wheels
Height: 160 mm.
Drum Inside Diameter: 12 mm.
Bolt Hole and Circle Diameter: 8 - 6 1/2 in.
From Kragen/oriellys...
the cheap version...
Raybestos Aimco-GS Brake Drum
Part Number: 1961DGS
Our Price: $71.99
Brake Drum: Aimco-Gs; Rear; 12 Inch X 2-1/2 Inch Or 12 Inch X 3 Inch Brakes; 6.29 Inch Overall Height
and the spendy version, almost 3x as much $.
Raybestos Advanced Technology Brake Drum
Part Number: 1961
PRICE $201.00
Brake Drum: Advanced Technology; Rear; 12 Inch X 2-1/2 Inch Or 12 Inch X 3 Inch Brakes; 6.29 Inch Overall Height
And from Pepboys, 73.00.
93wuntun
Postby TRENDZ » Sun Aug 02, 2009 11:35 am
My guess would be that the first one includes the hub.
TRENDZ
Postby 93wuntun » Sun Aug 02, 2009 12:37 pm
all pics show the typical drum with the dually 'hi-hat', no mention of a hub in any of them
93wuntun
Postby charger 69 » Fri Oct 16, 2009 3:53 pm
I ran into the same thing when I did mine. I was told the ones fo $79. were made in China and thats what I put on mine not by choice. Make sure your parking brake lever Works freely, mine didn't and I ground up the shoes on one side. :mad:
92 White D350 132K,mi. fuel screw in 3,5 turns automatic with a Hughes converter and 26K add on cooler.Aluminum wheels,second fuel tank,gooseneck hitch,air bags tach.and gages,
charger 69
Postby KTA » Fri Oct 16, 2009 7:08 pm
I would recommend Bendix or Wagner drums. The bendix are more pricey but I have had good luck with them. I had a set of Napas that were about $70ea that I had to turn in my lathe new because they had run out and caused brake shudder.
Postby BobS » Sat Oct 17, 2009 3:33 am
It always brings up this question in my mind: Is it made in the USA or Canada or is it just branded and packaged there?
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby chrislib » Sat Oct 17, 2009 9:46 am
I got some chinese drums from the local noname parts store at job cost (10% over cost, no tax). Ran me $26.00 a piece...i was shocked but they are nice and true and stop well.
It`s not about how hard ya hit...it`s about how hard ya can GET hit and keep movin forward.
93 W250 CC 4x4, Auto,7x010`s, D-Zilla/16cm, 5in exh, BHAF/Smoky...don`t call it ratty, that`s patina son!
chrislib
Postby charger 69 » Fri Dec 18, 2009 6:40 pm
chrislib wrote:I got some chinese drums from the local noname parts store at job cost (10% over cost, no tax). Ran me $26.00 a piece...i was shocked but they are nice and true and stop well.
Same thing,mine have about 10K on them now and no problem so far.
charger 69
Postby jwatso8 » Fri Dec 18, 2009 8:19 pm
93wuntun
i got a new set of rotor for my truck about 3 years ago. i got the cheaper china ones. i thank they were around 60 for a pair. its like they say (you get what you pay for). they were worn out in less than 20k miles. they were warped again. i took them to the parts store. and of course they couldnt machine them out. so i had to buy new one. ended pay 220 for the best one they had. havent had any problems out of them. so i would say, buy the best the first time around. just my opinion.
SOLD 92 D250 intake,S300,coolertubz,i/p MAXED,366 spring,Dennyt fuel pin,DDP 4,airdog 100,gauges, 4" d/p w/5" stacks
TRADED IN07 2500 6speed,intake,CFM+,Edge EZ chip,MBRP exhaust,B&W hitch
NEW 2010 3500 6.7L DRW 4x4 CrewCab 4.10 grears
jwatso8
