Windshield Wipers Broke
Postby Begle1 » Mon Mar 26, 2007 8:50 am
My windshield wipers don't work anymore. The motor works, but the wipers don't wipe. If I grab them then I can rotate them by hand easily, so I take it that a clutch or gear broke someplace.
Anybody have this happen before?
Anybody have this happen in the rain on the freeway before? :x
Postby CAJUN 93 » Mon Mar 26, 2007 9:18 am
pull the cowl, follow the linkage and you'll find (or won't find in this case) 3 nylon bushings. one has fallen out. they're easy enough to replace. mopar part# 3799089. list $3.50 ea. also available aftermarket in a pack of 3 in the help section (orielly's napa, etc). replace all of them while your in there. keep spares in the glovebox.
CAJUN 93
Postby CAJUN 93 » Mon Mar 26, 2007 9:21 am
btw, there is a distinct difference in the quality of the aftermarket and mopar ones (not just because i sell mopar parts :P ). the cheap one you can snap in by hand, the mopars require a vise or channel-lock pliers.
whatever you do, make sure they're pointing the correct direction when you snap them in, they will usually be ruind if you take em back out.
daryl
CAJUN 93
Postby dpuckett » Tue Apr 03, 2007 8:22 pm
I got the aftermarket ones, and had to use some channel lock pliers to pop them in. Looked identical to the ones I took out (which could well have been replacements), only without the aging.
Daniel
Postby Begle1 » Sun Apr 08, 2007 9:47 am
My problem was that the bar connecting the wipers to the motor fell off. There was a single nylon bushing, about 1/2 inch in diameter and 1/2 in tall, that pressured the wiper bar to the motor bar; it wore through after 17 years. New little bushing cost under $4.00 from Dodge.
