wooble when braking
wooble when braking
Postby bulltamer » Fri Aug 28, 2009 5:12 pm
it started today
when im braking from 70 to 30 mph it woobles kinda bad
stock '92 d350, auto, extended cab, 9 LEDs on each side, straight piped
coming soon: clear tail lights, fender lights, tailgate lights and clear second gen. cab lights
bulltamer
Postby cougar » Sun Aug 30, 2009 9:54 am
You are going to need a brake job. Your rear brakes go out of adjustment and the front has to take up the slack warping the rotors.
01 2500 "the work truck".
cougar
Postby peobryant » Mon Aug 31, 2009 12:50 am
Yep, the front rotors are most likely warped.
Postby dpuckett » Mon Aug 31, 2009 9:56 am
Likely rotors, but dont rule out anything else in the steering and brake systems.
Dan
wooble when braking
Postby bulltamer » Mon Aug 31, 2009 4:38 pm
thanks guys for the input
bulltamer
