my truck + ford-alcoa drw wheels = ?
Postby RumbleFish » Sat Sep 19, 2009 10:26 am
found 4 oem ford-alcoa dually wheels sorta local. the 97 and older style. my d350 has a dana 80 in the back. i think they will work on the front ok, but not 100% sure. the rear 80 i have no idea. iirc the 2nd gen trucks are hub centric. with steel inners maybe this wont be an issue? i dunno, and im looking for input. 2 tires look good, 2 look ok at best, but dunno if they are the 235/85's that i need. he is asking $350, is it a good deal or no?
Postby dpuckett » Wed Sep 23, 2009 8:42 pm
They will for sure fit the rear. Not sure on the fronts. They will need to be 5/8" naturally. Just have to see if they will run true without the coin fit lugs.
Dan
