Wheel spacer specs for 3rd gen wheels
Postby DieselSharker » Mon Oct 05, 2009 6:56 am
Well, I finally found a company to make me some wheel spacers for my 3rd Gen wheels. If you've seen my pics you can tell they look kind of odd thanks to the lack of backspacing. Here's the specs for guys that are trying to fit the 3rd gen wheels:
Bolt Pattern: 8x165.1mm (6.5")
Stock SRW Studs: 1/2"x20
Hub diameter: 121.3mm
Mine are being made at Motorsport Technology in Ca
http://www.motorsport-tech.com
The website is real handy. Has a form to fill out for all your measurements so you can price them out online. They make one- or two-piece adapters/spacers and can make them cut to the size of your hub and rim. They'll pretty much make them as thick as you want with pretty much any stud. You really only need about 1/8" or so to clear the rims but like I said even with 13.5" wide tires mine are still stuffed completely in the wheel wells so I went with 1.77".
1991 W250 727, 6" Skyjacker, 37" Dick Cepeks, Gear Vendor O/D, SDX 5x.014s, BHAF, home-made 4" intake, VE tuning & DennyT II pin, GDS 60mm with 16 cm, CoolerTubz 3" crossover
SUPPORT YOUR VETERANS!
DieselSharker
1992 2wd D250 cummins and I wanted to know if my 3gen
Postby reginald » Sat Nov 14, 2009 6:41 pm
1992 2wd D250 cummins and I wanted to know if my 3gen 4x4 quad cab cummins 2500 wheels would fit my.
Thought you may know as your making spacers for something, not sure what your building.
Thanks
Reg
Reg in Bullhead City, Az
reginald
