Rear Disc Caliper Clocking.
Postby Raymo » Tue Nov 10, 2009 1:10 pm
The Housing on my 80 will make for a tight fit between my rear caliper and the wide perched leaf springs. My question is, aside from having to bleed the caliper off-axle with a socket or piece of tube acting as the rotor, are their any braking performance drawbacks to running the caliper down 90 degrees from where it's at? From the factory its positioned the same as the front, with the same sized calipers and rotors as the front axle. Due to the size I'll be running an adjustable proportioning valve to the rear, so with that should I be set?
I've run something similar to this in the past with NO proportioning, but that was on a chevy with only 12" rotors all the way around with MUCH smaller bored calipers.
:shaking: Can you tell this conversion is burnin me out? Lmao.
'94 Chevy 3500-HD cab and chassis- IC Cummins, Getrag, NP205. 60 front, 80 rear- 4.10's.
Raymo
Postby RumbleFish » Tue Nov 10, 2009 2:08 pm
when i was converting my ramcharger to rear disc, i was trying to figure out if the calipers were supposed to be clocked toward the front or the rear. i called the company, and they said it didnt matter as long as the bleeder wa up. if you can bleed it off axle i dont know why it would make a big difference from a performance standpoint. if it were me, i'd gravity bleed it instead of the tube idea. sounds like a hassle imo.
Postby Raymo » Tue Nov 10, 2009 3:51 pm
Only problem I had with the gravity bleeding, is if I have them clocked down then my bleeder would be pointing so far down there would be hardly and fluid in the bore.I was just out measuring tho, and it's going to have to be mounted downward because there will be about 1.5" of interference thanks to my wide frame.
Raymo
Postby BC847 » Sun Nov 15, 2009 4:14 pm
I converted my D70 to discs with a kit. I was concerned with all the caliper stuff hanging on the bottom of the axle, so I put it up top.
That has the bleed port facing down. Other than having to remove the caliper to bleed, it's been no problem what so ever. :)
Postby jwatso8 » Thu Dec 03, 2009 10:14 pm
were did you get the kit for the D70 rear dics kit from. if you dont mind, how much did it cost. thanks
SOLD 92 D250 intake,S300,coolertubz,i/p MAXED,366 spring,Dennyt fuel pin,DDP 4,airdog 100,gauges, 4" d/p w/5" stacks
TRADED IN07 2500 6speed,intake,CFM+,Edge EZ chip,MBRP exhaust,B&W hitch
NEW 2010 3500 6.7L DRW 4x4 CrewCab 4.10 grears
jwatso8
Postby 921stgen » Fri Dec 04, 2009 12:07 pm
Heres his thread about them. If your not a member of dtr you will have to going to see pics
http://www.dieseltruckresource.com/dev/ ... l?t=146673
921stgen
