dakota farmer wrote:I was replacing my power steering pump this weekend. My old pump would work some of the times and not all of the time. It would blow oil out the top of the reservoir. So I replaced it with one that I got at NAPA. I put the pump and nothing happened. I bled the lines, made sure plenty of oil. Still Nothing. I then took the pressure line back off of the pump. I started the motor and no oil came out other than the oil that was trickling out because I took the hose off. Just curious if any of you have had this happen......defective pump? Idiot working on it? The sad part is I couldn't use it deer hunting and had to use a GAS suburban.
dakota farmer wrote:Thanks for the advice guys, it worked really well....took a few times but I can steer the pickup with one finger now. Thanks Again.
